Which Spark Plugs
I havn't seen much discussion on proper spark plugs to use. I'm at a loss and I would appreciate some help. Car is blown bbc on gas. Ignition is a msd 6al. I also wonder if there is enough ignition for this engine.
Depends,
How much boost are you running? I recommend NGK racing plugs. A 6AL would probably surfice for the street with minimal boost but if your racing and stuffing it pretty hard, I'd go on up to the 7 series. Cp |
It depend on the engine build whether you need long reach or short reach. I found Autolite plugs to be the best design.
| All times are GMT -8. The time now is 03:05 AM. |
