-   -   perplexing problem (https://www.racingjunk.com/forums/showthread.php?t=24352)
rabiddawg 05-22-2009 03:45 PM
perplexing problem
brand new AED 4150 carb
set floats and pump shot
initially I had a bog from standing start.
changed cams and shooters (BIGGER)
second road test:
stomped the throttle and spun tires through first into second.
:D
next day
warm car up to temp as before.
step on gas and bog is back???????
took off pump arms and bent the arms a little.
readujted accel pump for .015 at WOT.
ok back to smoking tires!
next day same ol bog again?
this got me scratchin my head?????
maybe bigger accel pumps ????
cepx111 05-23-2009 12:42 AM
You can go up to a 50cc pump on the primaries, but you've probably got another issue, are you sure your getting adequet fuel pressure?
rabiddawg 05-23-2009 02:51 AM
yes 6.5 psi at idle
5.5 psi at wide open
hammertime 05-23-2009 03:26 AM
Originally Posted by rabiddawg
yes 6.5 psi at idle
Not enough for me .. increase it a lb
rabiddawg 05-23-2009 04:36 AM
max for a holley is 7 PSI
hammertime 05-23-2009 05:00 AM
A holley carb ?
dparker 05-23-2009 06:29 AM
Lean problem. In the morning air is better bog. Later in the day air is worse no bog. Turn your idle screws out 1/2 turn. May need 50cc pump and/or little bit bigger squirters.
rabiddawg 05-24-2009 04:39 AM
hmm plugs are a dark tan and color change is at bend of the ground strap.
I do get some cutting up ( or muffled popping)on decel but didnt notice any pingng or detonation.
running leaded 110 sunoco gas
ill try going up 2 jet sizes and see what happenes
Tod74 05-24-2009 04:58 AM
I would call AED and ask them...would have thought the thing was closer than that out of the box...as far as the pump cams and squirters I mean.
itsabird 05-24-2009 06:24 AM
i woud put a 50cc pump on for sure, if you have another gauge, i would swap the old one out, i have seen gauges that were off as much 1.5 lbs, i would also try a little more pressure, good luck.
