-   -   engine trouble (https://www.racingjunk.com/forums/showthread.php?t=24355)
greenone60 05-22-2009 09:26 PM
engine trouble
i have a sbc 383 that the outer ring on the balancer has come a apart at high rpm say around 6900.the rest of the balancer stayed on the motor and the motor was steal running before i shut it down.do you think there might be some interal damage?
cepx111 05-23-2009 12:36 AM
I doubt it.
Pull the old one off and stick a new on there and go racing.
hammertime 05-23-2009 03:22 AM
Re: engine trouble
I've seen this happen before, all has been but there was 1 time I seen it cause a issue. Motor started to have a vibration after, if thats the case shut it off and pull it apart
dparker 05-23-2009 06:41 AM
I'd pull the filter, cut it open and check for any bearing material or metals. Just to be on the safe side. Won't take but a few minutes and $10.00 filter.
kbartley 05-24-2009 03:19 AM
balancer
x2 what they said.
Kris
kbartley 05-24-2009 03:25 AM
balancer
one more thing check the timing again. if you had a stock balancer the ring may have slipped alittle be fore it came off causing timing to be off. Let us know.
Kris
TS1955 05-24-2009 10:40 AM
At 6900 rpm's ya might want to get an SFI approved balancer. JMO
TS1955
Tod74 05-24-2009 11:35 AM
Sprint cars run with NO BALANCER AT ALL...but their crank most likely cost a bit more than yours. :)
greenone60 05-24-2009 11:50 AM
thanks guys for the info, and yes iam getting a sfi balancer.
THERATTLER 05-24-2009 01:43 PM
I HAVE BEEN RUNNING WITH NO BALANCER FOR YEARS , JUST HUB FOR BOTTOM PULLY :D
