CARB IDLE
WHY WON'T MY CAR IDLE WHEN I PUT IT IN GEAR.
I'd check torke converter may not be stalling right. If its a high stall converter it shouldn't effect idle to much.
Possible vacuum leak!
TS1955 |
CONVERTER IS NEW ATI 8 INCH.
I SHALL NOW CHECK FOR LEAKS AROUND CARB. |
HOW WOULD I KNOW IF CONVERTER IS NOT STALLING RIGHT?
Take the chips out and stall it up on the transbrake, see where it goes too. Usually on an eight inch converter, if your engine will idle fine in park it will idle in gear. Now if its starting to load up in park, you know its not the converter. You can check for a vacuum leak by putting your hand over the carb, it should pick up the idle. There is a number of things that will keep your engine from idling right. I just interupted that your engine idles fine when its not in gear and dies when you put it in gear.
Cam isn't right.
Originally Posted by CamBirdRacing
Cam isn't right.
| All times are GMT -8. The time now is 03:04 AM. |
