-   -   FUEL SPLASH (https://www.racingjunk.com/forums/showthread.php?t=24450)
JEFF69Z28 06-01-2009 09:12 AM
FUEL SPLASH
WHAT ARE THE CHANCES OF FUEL COMING OUT OF THE TUBES ON THE CARB WHEN LEAVING THE STARTING LINE AND CHOKING MY MOTOR FOR A SPLIT SECOND?IS THAT WHY I SEE SOME CARBS WITH A PIECE OF RUBBER TUBE GOING FROM ONE TO THE OTHER.
curtisreed 06-01-2009 10:19 AM
Chances can be very good. That is exactly why it is done.
Curtis
oldandtired 06-01-2009 12:53 PM
Curtis
x2 Dave
cepx111 06-01-2009 11:31 PM
Just make sure you have it vented on the top somewhere, notch the hose or put a TEE in it.
I've personally never had an issue with mine doing it - I run my bowl level(s) on the lower side of full just for that reason plus my vent tubes are short.
Cp
JEFF69Z28 06-04-2009 02:36 AM
WELL THE FUEL SPLASH WAS'NT THE PROBLEM IT STILL STUTTERED ON LAUNCH,NOW IM THINKING ELECTRICAL PROBLEMS,ANY THOUGHTS???
dparker 06-04-2009 04:43 AM
Do you have jet extensions in the Carb?
JEFF69Z28 06-04-2009 04:46 AM
YES.I ONLY NEED THEM IN THE REAR,CORRECT?
dparker 06-04-2009 04:53 AM
yes, I didnt realize it was your car that wasn't idling in the other thread. I think your problem is your still to lean at idle. Do you have removable air bleeds?
