-   -   PLUG GAP on blown sbc ??? please help (https://www.racingjunk.com/forums/showthread.php?t=24487)
viol8er 06-04-2009 04:23 PM
Hi, thanks in advance for the help!! I have a 414 sbc 8-71 dbs blower and enderly mechanical fuel injection. base engine is 9.2 compression, blower 10% underdriven, running f&l sp-1 or sp-3 fuel, same as vp c12 c14. Ignition box is a 7-al3 not digital. My question is what should I run the NGK v-power #8 sparkplug gap at? I was told between .025 and .030..... is this close?? Reason I'm asking is, at the top end of the track I have what feels like a random misfire, engine has plenty of fuel -- went 20 #'s fatter on the pill, Have taken 8 degrees of timing out of it and still the same. Please point me in the right direction if you are familiar with this set up, THANKS!!!
kwkracing 06-04-2009 06:40 PM
I run around .040-045. on my blown sbc on gas or alky. what is the timing set at? Why are you not burning alky?
THERATTLER 06-04-2009 07:23 PM
on my blown alcohol sbc motor I run 25 thou on the plug gap with a 7 al3 , any wider and I have miss fire at high rpm , thats just what my set up likes,,,,Paul :D
DaveKoehler 06-10-2009 03:22 PM
You can and have tried larger but I will say .018-.025.
Might check your pop off plate if you have coughed it previously.
Dave Koehler
http://www.koehlerinjection.com
bbchevy 06-10-2009 04:32 PM
miss
You NEED to Ditch the MSD Box and get a GOOD Mallory Mag,Super Mag 3 0r 4 and you will be GOOD to go!!!
Just talked to a freind in Indiana this Week same Problem,He Tryed the MSD Route?Took it out and went with a S/M 5 and its GREAT Now!
Later
G 8)
kwkracing 06-10-2009 05:06 PM
MSD works fine on blown carb or injected sbc and bbc's
bjuice 06-10-2009 07:37 PM
.018 TO .020
jmarksdragster 06-11-2009 06:23 AM
Dave Koehler
This is the voice of reason here, any time you increase pressure in the cylinder either with higher compression, NOS or forced induction you need to increase the intensity of the spark either by using a smaller gap or higher energy ignition. Smaller gaps are the easiest place to start.
andybyrd 06-11-2009 01:21 PM
Ok it is learning time for me and I'm loving every minute of it. 434 sbc gas 15.33 to 1 compression and NGK #8's is 35 gap on the plugs ok or should it be tighter.
Thanks Andy
dparker 06-11-2009 01:27 PM
Dave Koehler
I have to agree 100% Mark.....Dave it sure is a blessing for someone of your stature to take the time to come on this site to give some advice. As for me its very much appreciated.
