-   -   ** mopar guys beware of 440 source check your parts good.** (https://www.racingjunk.com/forums/showthread.php?t=24524)
wedgehead426 06-07-2009 06:08 PM
[b]
mopar guys beware of 440 source they don't stand behind there stuff in good faith. some of us have to buy things when we have the money even when we will not be using it for a while well i did that and had a problem with my stuff they told me when i called its past the return date. well i could see that if i had mounted it already and then used it for a while but i just put it on 4 weeks ago to get it ready to go to the dyno shop and the water pump its self the shaft or end piece was bad and they said they could do nothing for me. *** just be careful i won't ever buy from them again period.*** :x :x** THAT IS MY RIGHT TO CHOSE I WILL ALWAYS BUY LOCAL OR FROM A GOOD MOPAR SUPPLIER.**
** I AM NOT TELLING YOU NOT TO BUY THERE JUST BE VERY CAREFUL AND CHECK EVERYTHING AND NOTE IT AND TAKE PICTURES OF ANYTHING BAD OR DAMAGED AND SEND IT BACK IN TIME OR YOU WILL BE LEFT OUT IN THE COLD LIKE I AM HAVING TO BUY AGAIN.** I WILL NEVER DO BUSINESS WITH THIS WEST COAST COMPANY AGAIN PERIOD THIS IS MY RIGHT AND I WILL EXCERISE IT TO THE FULLEST.**
oldandtired 06-08-2009 05:20 AM
This is not about the 440 company listed, but hear me out as this will always be an issue for builders.
I purchased an item, pulled it out of the box, casually inspecting it and then put it on the shelf. Several weeks later I go to install this piece (roller cam) and find it had damage on one lobe.
I returned it and they called and they said I damaged it. They had the piece so I had no choice except to repair the lobe. Then they sent it back $90 COD (I had originally paid for it with a credit card).
I'll never do business with this west coast company again.
Dave
nopro 06-09-2009 07:39 AM
ever buy a set of custom pistons, what do they tell you ? get it, look the part over, it's not hard to do. if called with in a day or two (best within 1 hour) it's shipper or the company fault. to long, who's to say, plus the policy is up front on returns.
