-   -   Rons 1/2 pump and alternator (https://www.racingjunk.com/forums/showthread.php?t=24581)
onedragracer 06-11-2009 07:14 PM
I remember reading a post someone had about mounting brackets for a rons pump, alternator, and vacuum pump but I can't find it. I've got a BBC in a dragster and will be using all three if I can find a link to the website that sells them. Any help wound be appreciated.
Thanks
James
hammertime 06-11-2009 07:47 PM
http://www.motorsportsinnovations.com/
dparker 06-12-2009 05:25 AM
Hey David, do you still have those pics of how yours is mounted. I did mine just like that and if worked great for me. James traded his roadster for a Danny Nelson dragster. I guess you can say I came over to the Dark Side.........
hammertime 06-12-2009 01:38 PM
I do, if he has a nelson car there is no reason to spend the money on the mount deal as it can be done without.
James shoot me your email and I'll send ya some pics
hammertime 06-13-2009 07:43 AM
sent pics hope it helps I am sure I have more somewhere or could shoot ya a few more.
Mine is rons 0 1/2 pump with crank trigger under it on bottom left, moroso vacuum pump mine is on top right of motor but wouldnt matter which side you mount it actually easier on left but my valve covers were drilled backwards of this, just a normal moroso vacuum pump mount. 100amp east coast alt, with east coast alt mount on bottom right. Not really even a tight fit.
onedragracer 06-13-2009 02:38 PM
Thanks for the pics David, I have plenty of room but I couldn't get the layout to make since. Now I see what I have to do. Thanks again.
hammertime 06-13-2009 04:33 PM
not a problem should save ya a few bucks
