Steering wheel switch and bracket
This is probably the wrong place to ask, but I want to put the line lock switch and the tranny brake switch on a bracket mounted to the steering wheel. I can't seem to find anybody that makes the bracket. I know I saw it somewhere but, old age prevents me from remembering where. If anybody knows, I would appreciate your help.
The bracket I use most often is the spokes that are on the steering wheel itself. I drill a hole in one that lines up with where I like my hand to be and use a double nut to lock it in place. If you have no flat spokes on yours, then a U-bolt holding a piece of aluminum on a spoke with a hole in it for your button may also be an economical choice that you can make to fit your steering wheel better than a generic bracket purchase?
Bruce |
We are asuming you are driving a door car. Therefore all you need to do is get a somewhat flat steering wheel. If it comes with holes, you are half done!!
Dave |
| All times are GMT -8. The time now is 11:36 PM. |
