-   -   Plug Wires (https://www.racingjunk.com/forums/showthread.php?t=24609)
wetill70 06-14-2009 10:45 AM
Plug Wires
I have a spark plug that is located very close to the header and the heat from the header is burning the plug wire. Is there anything I can do to prevent this or special plug wires I can use?
Thanks for any advice.
MEMRACING62 06-14-2009 02:07 PM
http://summitracing.com/parts/ACC-170079/
Tod74 06-14-2009 02:22 PM
What kind of car/engine and which cylinder is it? My Nova with BBC has this issue on # 7 I had to make that one wire a lot longer and bring it in from the bottom. Also had to use 45 deg boots instead of 90
wetill70 06-14-2009 07:21 PM
My problem is with the #6 spark plug and I am going to try what you said and see if that solves my problem. Thanks for the information. I don't like Centerline either.
radicalz 07-19-2009 05:33 PM
well try this site they have straight, 90, and 45* boots plus...boot protectors http://www.performancedistributors.com/livewire.htm
TS1955 07-20-2009 02:25 PM
Accel makes short "Header" plugs. You might try to see if they are available for your application.
TS1955
TheRabbit 07-20-2009 06:50 PM
Get the longer wires and run them all under the headers. Problem solved forever!
bbchevy 07-20-2009 08:00 PM
Headers
Another thing to Concider?Having your Headers Ceramic Coated,you would NOT Beleive the difference in Outside Header Temp.
NITROPLATE=It WORKS!
Later
G 8)
