-   -   pinion angle (https://www.racingjunk.com/forums/showthread.php?t=24610)
sds10racer 06-14-2009 03:07 PM
pinion angle
on my s10 w/leaf springs, i have 5* angle. should i keep this angle if i preload my slapper bars? or should i either let the bars come up to the spring on launch or change the angle to less than 5* and preload the bars? in the past i preloaded the bars and had 1.57 60' times, but now i've removed the lowering blocks and 1 spring leaf to lower it. the bars are the type you clamp to the springs instead of using the spring plate to mount them.
