-   -   What gauges should i run with a blower? (https://www.racingjunk.com/forums/showthread.php?t=24670)
pennywise419 06-19-2009 01:30 PM
what gauges should i run with a 671 blower? Ive seen boost/vac. gauges boost gauges blower pressure gauges and im not sure witch one to use. Also other than speedo, tach, oil pressure, water temp, volts, what else should i use. Thanks for any help
