-   -   'Glass body mystery.... (https://www.racingjunk.com/forums/showthread.php?t=24675)
TheYellaBrick 06-19-2009 03:37 PM
http://blog.cardomain.com/2009/06/19...d-in-junkyard/
THERATTLER 06-19-2009 03:47 PM
THAT HAS TO BE AN EARLY COUPE PROMOD THAT DIDN'T TURN OUT RIGHT OR SOMETHING,,,,IT STILL HAS ALL THE MOLD EDGEING IN THE DOORS , , WELL,,,THATS WHAT IT LOOKS LIKE TO ME :oops: :oops: :oops:
andamo 06-19-2009 05:31 PM
I'll bet that is the buck that Carl Moyer had made of a '38 Chevy to be used in the early Pro Mod days. At first I thought it might have been Scotty Cannon's Willys, but then I noticed where a side "window" should be.
Tod74 06-19-2009 06:49 PM
pardon my ignorance....but WTF is a "buck" Is that the mold the body is made from?
TheYellaBrick 06-19-2009 09:27 PM
That is correct, Tod. It's quite an interesting multi staged process to produce even a single part in 'glass or any composite.
You start with a 'master' or 'buck', which is exactly what you want to reproduce. It is a 'male' and is braced and supported to prevent any distortion. The 'buck' is usually used only once and that is to form the 'female' part of the mold. That 'female' mold is severily braced and built very strong to prevent distortion as it will be used many, many times to produce the actual parts that will be used.
Body bucks are kept as they can be modified to produce a slightly different female mold for a slightly different part. and on and on......
MEMRACING62 06-19-2009 11:23 PM
ONCE AGAIN I LEARNED SOMETHING NEW :!: :idea: :idea:
rob41willys 06-21-2009 05:02 PM
I was thinking 37 chevy promod? Where's the front end? Carbon fiber anyone!!
CamBirdRacing 06-22-2009 11:22 AM
Helped a guy build boat mold this way. I didn't do any of the fiberglass work, I did the framing to stiffen the mold around it. Lots of box tubing a wire feed welder wire.
