Question about msd
I had a vac leak and my motor was running rough. I found the problem and fixed it but know I have a bad miss. Was wondering if my msd btm went out. I was told that if the msd is bad it would shut down the whole motor and would not just shut down one cylinder. I also noticed that the passenger side headers are getting hotter that the driver's side??? Can anyone help?
Thank you CPT.RON |
Have you checked your plugs, sounds like you may have fouled one?
What kind of Fuel induction do you have?
Not plugs changed them wires too. I am running two hollys on two 671 blowers.
CPT.RON 8) 8) |
2-BLOWERS?
CPT.RON 8) 8) Later G :? |
bbchevy Tell me how to post and I will its been so long sence I have posted anything I forgot how to.
CPT.RON :cry: :cry: |
Blowers
Ron,
Did you FIND the PROBLEM? Also sent you a PM with a email add.to send the Picts. Later G 8) ALSO,wanted to let you know?I Use a 6-BTM in my 38.If you would like to try it i would send it to you? |
| All times are GMT -8. The time now is 08:02 PM. |
