-   -   holley blue pump is starting to drag or slow down (https://www.racingjunk.com/forums/showthread.php?t=24698)
tommysears 06-21-2009 02:43 PM
after the car runs for 15 minutes the pump sounds like its slowing down, fuel pressure stays at 7psi from my regulator. i am going to try and rebuild it, i see that holley sells two different rebuild kits, a rotor and vane kit and a check valve kit. should i buy both rebuild kits? i have never rebuilt a holley pump before, is it pretty simple or should i just buy another fuel pump? any help would be appreciated. i do run a relay to the pump, i think its just getting old, its 3 years old now.
Scooterz 06-24-2009 02:20 PM
Hey Tommy-
Feel free to correct me anyone, but your pump is a vane style & not a geerotor (such as a "black" Holley). If you are going to rebuild it, stick w/ the vane as it is compatable for a regulator. The Black Holley geerotor is internally regulated. Hope this helps. Scooter
