-   -   What Fuel Pressure (https://www.racingjunk.com/forums/showthread.php?t=24755)
jreiley 06-27-2009 06:54 AM
What Fuel Pressure
I replaced a regulator on my 350 sbc, stock bore and stroke, 11-1 compresson and really good heads. The regulator came set at 7lbs. Is this enough pressure? The regulator is a bypass regulator. The pump is a holley blue pump.
dparker 06-27-2009 11:31 AM
I won't run a bypass regulator with a Holley blue. A good static regulator would work better in my opinion. Magna fuel 2 port regulator, $129.00
jreiley 06-28-2009 07:17 AM
I had no intention of running a bypass line until the tec inspectors at our local NHRA track told me it was highly reccomended.
TopspeedLowet 06-28-2009 08:16 AM
If the info came from your competition, that would explain there recommendation. That is a real bad technical recommendation! There is not a reason to use a bypass on a holley blue unless you want to starve your engine for fuel and that is really the facts of the matter. Tec inspectors at your track are only there to enforce rules for safety. Sounds like you have a "REAL SHARP" tec inspector, if you know what I mean. There is no safety advantage nor any positive performance advantage's to running a bypass regulator with your holley blue and especially not a safety advantage running your engine lean!!
I use a set pressure using a blocking regulator at a touch under 7 PSI for most all applications. Off road will like lower pressure, maybe 5.5 to 6 PSI to prevent flooding in hill climbing sports etc.
The use of By pass regulators should only be used with belt driven pumps and some front mounted fuel systems that have huge capacity Weldon type pumps.
Bruce
jreiley 06-29-2009 04:17 AM
Being somewhat of a novice, I agree with what you have to say. I was quite surprised by this tec telling me a bypass regulator would protect my engine. The regulator is set for 7lbs so it should not hurt anything, I hope. I'm going to rebuild and bump up the hp on this engine this winter. At that time I may replace the fuel pump.
