-   -   SHP MAIN BOLTS (https://www.racingjunk.com/forums/showthread.php?t=24758)
et7333 06-27-2009 10:05 AM
SHP MAIN BOLTS
Which main bolts do you use with the 4.030 SHP block,Dart or?
hink 06-27-2009 11:30 AM
Re: SHP MAIN BOLTS
Well main bolts don't not have much to do with a 4.030 bore but the ARP bolt kit number is 134-5002 and the stud kit is 134-5402
The grade 8 bolts and washers Dart supplies seem to be pretty good.
Once the hardware is installed you may want to check the housing bores for size as it amy need an line hone.
et7333 06-27-2009 11:57 AM
Well Carl I'm still going to purchase block from you,retired and got married so some of my racing projects are taking a more time.Thx for the info
hink 06-27-2009 12:34 PM
OH NO your in trouble now LOL.
