-   -   Need a clutch fork... (https://www.racingjunk.com/forums/showthread.php?t=24804)
gcp 07-01-2009 07:19 PM
I'm putting a 4 speed Muncie in my Chevelle and was hoping to use a bellhousing I've had laying around the shop for years.
Turns out the bellhousing, GM casting number 360162, was used with the H-body (Monza) and has a pull style clutch fork. I'll be setting up the car with a Wilwood master cylinder and pull-type slave cylinder. Now all I need is a clutch fork.
Is anyone using this similar setup?
Does anyone know where I can get a clutch fork for this bellhousing?
