-   -   sbc shaft rockers (https://www.racingjunk.com/forums/showthread.php?t=24814)
qiksix 07-03-2009 05:15 AM
sbc shaft rockers
Yes i know jesel/t&d are top shelf, is there anything else anyone would recommend as a tight budget shaft rocker with a .220 offset.
So what's the difference between j/t's sportsman and j&t's comps. These are going on a bowtie headed chevy v6, can anyone give me stud spacings on std v8 and 40/60s as i think mine are close to 40/60s as i can modify holes to fit
curtisreed 07-03-2009 06:34 AM
Have you looked into the Yella Terra rocker system?
Curtis
zipper06 07-03-2009 10:13 AM
The std. stud spacing on a sm/blk chevy between the pairs is 1.773, comp cams now has a shaft rocker system a little cheaper than Jessel and T&D, i personally T&D because of their service, when you talk to them you get real people who know their product and will help in any way possible.
qiksix 07-05-2009 04:45 AM
I looked at yella terra's, they don't look very rigid with there stud type mounting.
As i'm in australia it's hard to call but i've emailed t&d with no reply yet.
Can anyone see a problem if i use a v8 set and modify the mounting holes( 0.020-0.030), would i be able to centre the rocker over the valve.
zipper06 07-05-2009 05:00 PM
You would have to elongate both the mounting holes and the c'bore since the bolts are counter sunk into the mounting base. But could be easily done with a vertical milling machine.
qiksix 07-07-2009 12:45 AM
Yeh Zip, that's how i was going to do it.
Anyone on here a jesel/t&d dealer or have a set willing to ship down under.
