-   -   electric water pump (https://www.racingjunk.com/forums/showthread.php?t=24820)
john910 07-05-2009 11:16 AM
electric water pump
dumb question. what way does water flow? does it go from lower rad. hose to water pump then out to top hose to rad? is it possible to have pump runnig backward? does the lower hose get warm first or upper?
fla1976 07-05-2009 11:36 AM
Flow
Generally, it flows from the engine thru the thermostat, thru the upper hose and into the top tank of the radiator. Flows down the radiator and dissipates heat thru the fins and to the lower hose where the water pump feeds it into the engine again.
MEMRACING62 07-05-2009 11:55 AM
what type of engine do you have?
john910 07-05-2009 12:48 PM
electric water pump
its a sbc.
MEMRACING62 07-05-2009 03:08 PM
ON SBC WITH HEATER CORE RETURN GOING INTO THE RADIATOR TANK ON PASSENGER SIDE OF CAR , BOTTOM HOSE WILL HEAT UP FIRST. WHEN THERMOSTAT OPENS THE TOP HOSE WILL GET HOT. WATER ENTERS ENGINE WITH THE LOWER HOSE AND RETURNS TO THE RADIATOR THROUGH THE THERMOSTAT AT THE TOP
