-   -   Unisteer r & p for 67 Camaro (https://www.racingjunk.com/forums/showthread.php?t=24831)
tupeloracing 07-06-2009 01:24 PM
Is anyone using the Unisteer bolt on rack and pinion for a 67 Camaro? If so, can you post pictures of your fabricated steering shaft? I'm having trouble fabing one up that doesn't want to bind. Thanks!
Scooterz 12-31-2009 02:34 PM
I wanted to see how this project turned out. Did you get this done & how did it go??? Wondering same thing. Is yours a BBC? Thanks, Scoot
SG60IMPALA 01-02-2010 08:05 AM
Rigsby . I reworked one that someone had started to install. it had a BBC with headers. I actually had to cut out #1 primary tube then install shaft and reroute primary tube closer to block to clear shaft. hope this helps. if not call me and I see if I can explain better. Bryan 931-623-9512 ALLEN FABRICATION SERVICE . send me your e-mail and I send you a pic of what i done.
Scooterz 01-07-2010 01:04 PM
Thanks!! My e-mail is [email protected] & I would love to see the pic. I think I understand where you are coming from... the shaft will have a major contact issue w/a BBC & big headers (like I have, Hookers super comp). I knew the shaft would be the main problem.
