-   -   NO FIRE From My Coil. (https://www.racingjunk.com/forums/showthread.php?t=24885)
andybyrd 07-10-2009 11:49 AM
Ok, my son inlaw has a 302 ford with a digital 6 MSD, last week at the track it just quit firing I replaced the coil and no change, called msd and they said it was the magnetic pick up in the dist. is there any way to make sure. just buy the thing.
Andy
curtisreed 07-10-2009 02:57 PM
Andy,
You can check the ignition first it's really easy.
http://www.msdignition.com/page.aspx?id=3206
I just went through this myself and had to change the pickup on my distributor. I checked it all first to rule out everything but that. Only had about 30 passes on this distributor when it failed.
Curtis
andybyrd 07-12-2009 07:24 AM
Thank you Curtis for the site, . I'm doing that check now.
Andy
TheYellaBrick 07-24-2009 11:52 AM
I just burned up a whole hour on the MSD site !! GREAT info !!!!!!
hollowayshotrods 07-30-2009 09:19 AM
Andy, I had the same problem a couple weeks ago. The link Curtis gave you is the same way I figured mine out. I am connected to the ignition hot wire, no coil spark. Traced it to a bad connection at the MSD/ignition wire connection. Was up and running again in about 30 minutes.
I hope you have it your running now, even if it is a Ford :!:
