-   -   Electrical problem (https://www.racingjunk.com/forums/showthread.php?t=24955)
wlpatterson 07-15-2009 10:15 AM
Electrical problem
I have Buddy working on a ford ranger about a 1988 that shuts down when you hook the amp gage wire up.The Alt has 2 plugs which the amp gage wire runs from one of them,the wire runs from the alt to the gage & from the gage to the ign switch.the Ign has been replaced,the alt & the Inst.panel has been replaced.The truck runs fine until you connect the amp wire & its like you turned the key off.Anyone experienced this problem? I appreciate any & all help--
mopar1968 07-15-2009 10:33 AM
Trace the wire shorted to ground somewhere, the wire in question, snip it at the alt [only if you want] run a new one in it's place, see what happen's :!: :!:
''JUST MY TWO CENT'S WORTH''
wlpatterson 07-15-2009 11:30 AM
Already done
I have tried that,Im sure something is going to ground,finding it seems to be my problem-
wlpatterson 07-15-2009 02:34 PM
You will never believe!!
He found the problem & this is the 2nd garage thats tried to fix it. I would have never figured it out,(of course Im not best ) Im going to let it stay for awhile & see if anyone can figure it out--Thanx
