-   -   BBC head ID (https://www.racingjunk.com/forums/showthread.php?t=24956)
Drtmod5 07-15-2009 02:09 PM
BBC head ID
Can anyone give me info on these stock oval port BBC heads & if they are decent or is there something better other than a big priced alum head?
Casting #'s on both are 3917215
1 has E 247
1 has F 87
Any info appreciated
Dave
ejm 07-15-2009 02:17 PM
3917215, 1967-69, 396/427, Closed chamber, 109 combustion chamber
Drtmod5 07-15-2009 02:24 PM
Ok so now I know what they are, but are they any good or would you try to find something different?
CamBirdRacing 07-16-2009 03:30 AM
I have a set of those, 68 year model, for sale, if you need an extra pair.
sp2816 07-16-2009 05:55 AM
It really depends on what you are trying to do, but they came from the factory with 2.06" and 1.72" valves. If you are putting them on a flat top engine they will boost the compression up by a couple of points, but they could really stand to have the larger 2.19" and 1.88" valves installed and bowl work, if putting them on a 427 or larger engine. The normal consensus is that the open chamber heads work better with flame travel and combustion, but I have run 9.50's with closed chamber rectangular ports on a 468.
Bill Mitchell
