-   -   '69 Camaro Mono leaf rear with Multi Leaf springs (https://www.racingjunk.com/forums/showthread.php?t=24963)
thompsonjoedeals 07-16-2009 02:44 PM
Will it work and what modifications will be needed?
Thank you
johnracer 07-16-2009 03:46 PM
Should bolt right up. As I recall, the spring perches on the early Camaro's weren't flat. They were cupped around the sides of the spring. I'm pretty sure the multileaf perches were deeper, so you may need to use u-bolts on both sides instead of the t-bolts that were stock on the front side of the axle. Also the rear shocks are longer with the multileaf setup.....
oldandtired 07-17-2009 06:36 AM
The rubber pad that goes between the spring and perch are different. You will have to modify them with a razorblade.
Dave
thompsonjoedeals 07-17-2009 04:41 PM
thanks
thanks to all
