-   -   Brodix HV 2001 (https://www.racingjunk.com/forums/showthread.php?t=24964)
tkilby 07-16-2009 03:54 PM
Brodix HV 2001
Has anyone used a brodix hv 2001 intake? What size engine do they work best? How do they perform compared to other intakes? Thanks!
supergass 08-29-2009 05:59 AM
It is a very good intake. I like the look of it better if your not using a transbrake for throttle response. One thing they need is work just under the carb by a proffessional porter because the 2inch cast spacer doesnt transfer very well to the intake. There are some siginificant gains there because it turns back in toward the center before the opening of the port. Mine had to be welded and cut a little more just under the cast -on spacer. Mine is on a 565.
hammertime 08-29-2009 06:45 AM
Re: Brodix HV 2001
whats the motor ?
tkilby 09-08-2009 04:38 AM
It is on a 555 cid.
