BG 400 Install
Can a BG 400 be installed in any direction?
I am assuming you mean in any position. That answer is yes.
Dave |
WHAT :?:
Zip. |
If you are asking can you mount it with the motor to the side or with the motor down, I would discourage you from mounting it with the motor down. If you lose a seal inside fuel can run down into the motor.
Curtis |
You gotta remember these things are GRAVITY fed. So position it so gravity works for you. They pump well, they don't suck so good.
| All times are GMT -8. The time now is 12:41 PM. |
