-   -   carb spacers (https://www.racingjunk.com/forums/showthread.php?t=25009)
bigmack 07-20-2009 05:21 PM
carb spacers
what's the advantage of running a carb spacer. have any one used a super sucker spacer or wilson or what's the best one out. thanks.
tcarda 07-20-2009 05:29 PM
Re: carb spacers
I have used a 2" aluminum super sucker and it seemed to work for my engine. Every engine seems to like something a little different.. JMO..
rob41willys 07-20-2009 06:49 PM
Depends on the engine. I tried a slew of different spacers on the dyno before and some gained power, some lost power and some didn't make any change at all.
mopar1968 07-20-2009 07:44 PM
Now this is something i have never understood, just what do they [ spacer] do :?: I gave up don't run one at all :!: :!:
''JUST MY TWO CENT'S WORTH''
cepx111 07-21-2009 12:37 AM
I run a spacer but only for it's insulating properties, its a moroso 1/2 laminated wood spacer, keeps my carb cool as a kitten.
Back to your question, every motor is different some respond to spacers some don't.
Generally speaking the taller the spacers like a 2 inch open one add plenum volume which should net you more top end HP, the 4 hole spacers add torque, how much is debatable.
Some companys claim some pretty substaintial gains but every combo is different - what worked on their test mule may not perform well on your set-up, kinda a crap shoot if you ask me
JMO>Cp
