dart big m chevy block
does this block take the 300 taller lifters with solid roller?also will this effect pushrod length or is the cup in the same spot with just a taller body?
Cup is in the same spot just taller body. A lot of people use them.
Re: dart big m chevy block
Have your machinist check the clearance on the lifter bores. Both my blocks had to have the lifter bores hone to the proper clearance. It can be catastrophic if the lifters stick . Needs about .0015 to .002
x 2 supergass
Originally Posted by ashbros
x 2 supergass
Dave |
I'd hope any place you guys took your stuff to would check this .. if not run ! :D
| All times are GMT -8. The time now is 01:20 PM. |
