-   -   Something to Check (https://www.racingjunk.com/forums/showthread.php?t=25047)
kwkracing 07-23-2009 08:15 PM
Something to Check
I was outside changing the tires on my blown street car when i noticed the lug studs seemed a little loose. I pulled the ford drum and tightened all of them before putting the wheel back on. I am posting this just to maybe prevent someone else from having a bad problem..... Sure maybe when i ran the lug nuts down the wheel would have stayed tight even thou the lug bolt was not tight against the axle or maybe it had been loose? Its just not one of those things i normally inspect, until now!
