solid roller cam specs for 509 whippled/cooled
going through the motor in my 25' ultimate warlock sxt cat, stock 502,
hyd. roller (stock) w/ a whipplecharger/whipplecooler setup making 6lbs of boost. never set up a motor for an outdrive , and I know I'll only need to rev it maybe 5500-5800rpm. new comp ratio will be about 7.9/8.0to1 had 8.75to 1. should I stick to around 230/[email protected] on a 112 or 114? or should I, could I go bigger? the bravo 1 IS the weak link in this setup! |
Leave the cam alone and crank up the boost. 6 PSI is nothing, and it'll be even less with the compression loss.
With an inter cooled Whipple, you can throw a TON of boost at it. |
| All times are GMT -8. The time now is 06:51 PM. |
