-   -   recomendation (https://www.racingjunk.com/forums/showthread.php?t=25151)
wildo23 08-02-2009 03:36 PM
recomendation
hi i have the camaro z28 1986the car weight 2450 with me,the car runs 8.87 a 153 mph seg 1/4 miles and the 1/8 5.65 the 60ft1.24.the motor is 540 piston 14to1 the block bored 4.5 rods 6.535 the roller cam 800 lift the heads 320 intake carburetor 1150 and thew converte stall 5800.I boot 5200 with transbrake and change 7400.the transmssion powerglide planetary 1.80 and the gear 4.56.you think the engine is new and just have 2 pass that I recommended that I do I was thinking to change the gear to boot longer.thanks
curtisreed 08-02-2009 04:33 PM
wildo I think something may be getting lost in translation. Are you asking if you should change the rear gear to a higher numerically gear??
Curtis
wildo23 08-02-2009 04:56 PM
hi
yes ,maybe change the gear 4.86 what recomendation
chrisr 08-02-2009 05:44 PM
From what I understand you are shifting at 7400. What are you crossing the line at? Also, where did you determine your shift point: dyno reading or ???
wildo23 08-03-2009 06:52 AM
h
shifting at 7700 in 1/4miles
curtisreed 08-03-2009 07:33 AM
Re: h
What is your finish line RPM now with the 4.56 gear?
