sbc timing?
I have a friend that seems to have all the answers :shock: and does not time his engine with a timing light he does it by ear :lol: I was just wondering what he was leaving on the table? thanks in advance.
if its a street engine ..probably nothing...thats the way we use to set the timing back in the day..turn the timing up until it spark knocked then back it off a tad and lock her down.
if its a Race engine he could be missing a lot..these need to be on the Money for optimal performance.. |
if its a Race engine he could be missing a lot..these need to be on the Money for optimal performance.. set it by ear then see were your at with a light so you know.JMO |
Actually, you can set it by looking at the plugs... A deaf guy could do it.
When i first got to injected cars, i watched a guy assembly the front drive, flow some air threw the top hat and adjust the barrel valve, fire the new motor, move the timing by ear and done..... I didnt believe at the time he had the timing set by ear to what he said it was.... i checked it with a light and dead on.
We used to set the timing on street cars by riding on the fender with car in first gear. The driver would advise the RPM and you could definately feel the sweet spot.
Dave |
Hey guys another ? about this timing thing, I'm not a Bad A*s Mech. but I can figure a few things out. But I always ask when in dout of something of this magnitude because timing is very Important, so let me ask this. if you were to set your timing @ 44 or 48 by mistake and it was perfect @38. would this cause severe engine damage or would the engine just not run right. Now I always use a light but I'm just curious what would happen. I know back in the olden days it was that if your timing was advanced to much it would run hot and have a draging on your starter when trying to start it after it heated up. and this was just on our steet cars with points and condensers
it was like you new you were to advanced to much so we would just back it off till it started when Hot and everything was ok, to make the ? simple what would happen if you advance your timing to much. Thanks Andy |
pre ignition ( the ping) would hurt power and motor.
go to far and the motor will stall. But I could be worng! |
| All times are GMT -8. The time now is 10:04 AM. |
