-   -   Calculating Compresson Ratio (https://www.racingjunk.com/forums/showthread.php?t=25243)
jreiley 08-09-2009 07:32 AM
I know the bore and stroke of the engine, but not the compression ratio. This is a running engine, i.e. heads on it. How can I figure out the ratio.
OneBadGMC 08-09-2009 08:39 AM
Pretty much impossible. If you know the cranking compression, you can get an idea of final dynamic compression.
jreiley 08-09-2009 09:03 AM
I know the cranking compression.
Tod74 08-09-2009 11:21 AM
OH NO......
http://forums.racingjunk.com/viewtop...mpression+test
OneBadGMC 08-09-2009 12:07 PM
That was a comical read...
There are, however, enough astute engine builders over on www.yellowbullet.com that can give you a basic idea what the dynamic compression is based on cylinder pressure.
Specifically, the guys that do the 'pump gas drag' motors. Trying to squeak every last pony out of a given combination by maximizing dynamic compression without detonation.
bbchevy 08-09-2009 12:23 PM
Whats New WJ?
The MAIN QUESTION Here is................................................ ..............?
Did the Fellow Ever get His ARM out of the HEADER?
Later
G 8)
Tod74 08-09-2009 01:04 PM
I agree with this. Lots of smart dudes over there...Just make sure you go to the newbie thread and introduce yourself first. Trust me on that one. :lol:
ashbros 08-09-2009 03:11 PM
What a read.... LOL
That writing craftsmanship was suttle but to the point.....
I am still trying to figure out who road the best pony on that one... LMAO
By the way, all of you forgot to factor in the 3/4 duration on that stroke and compression calculation..
When you get it figured out let me know what you come up with....
ashbros 08-09-2009 03:12 PM
Guys, I can't help it I am still rolling over that one. My ribs hurt sooo Bad............ :lol: :cry: :lol: :cry: :lol: :cry: :P
OneBadGMC 08-09-2009 03:39 PM
Was a hard lesson learned for the kid repeating bad information like a parrot and then defending it. I bet his buddy caught hell over it.
