keep breaking tranny mounts on 94 camaro v8
my beuudy broke about 6 motormounts on his slightly modified stoick v8 engine in his 94 camaro. is there some reason for this or a factory problem that he should know about. any suggestions thanks chevy art
broken traqnny mounts
meant to say tranny mounts in the above post, and not the motor mounts thanks chevy art
Are the motor mounts good?? What part of the tranny mount is he breaking?
I seen this alot in them camaro's - I don't know what it is but they break trans mounts often, if you start making any big power with the motor the problem only gets worse.
A friend of mine finally ended up putting a poly urethane mount in his 95 Z/28, hasnt broke that one, not yet anyway. Cp |
Cp |
broken motor mounts
thanks guys for instant response. i will as him obout the motor mounts and what part of tranny mount he is breaking. i told him to use the posyurethane tranny mount, but he said they are too stiff, but i think he has to go to one of those to solve the problem thanks again chevy art
The torque arm is mounted at the transmission on those cars and that is helping break the transmission mount when the rear is rotating and pushing the torque arm up in the front. The cheaper fix is the poly mount, but aftermarket torque arms and mounting will fix it. I have seen straps made to help limit the upward movement of the transmission to keep from breaking the mount.
My 94 F/B v-6 keeps breaking them. They are a hydralic setup from the factory. POS if you ask me. so now I am driving around with a broken tranny mount. I just don't get on it, makes the tranny hit the tunnel. I need to put a poly one on there. Too Lazy.
| All times are GMT -8. The time now is 11:34 AM. |
