Dome Pistons - Why
Is there any advantage to using dome style pistons?
More compression?
More compression ... in the past we've cut the heads a long ways and keep a flatter piston to get better flame travel
Dave |
in the high end markets, Pro Stock and Nascar Cup, the cylinder head chambers are getting smaller with shallower valve angles. This alows either a flat top piston or a dished piston to keep the compression up and still get good quench and flame travel.
yep, acomplish the high compression with a flat piston and make
the chamber small, but for those with large chambers can use the dome to fill the chamber, but flats are a better plan to get high compression, good luck :wink: |
Re: Dome Pistons - Why
Zip. |
Zip. Curtis |
| All times are GMT -8. The time now is 06:04 AM. |
