NEED HELP!!!
What do I have to do to convert from power brakes to manual on a 97 sonoma. Do they make a kit and do you have to change the master cyl. also.
brakes
I would check the part numbers for both master cylinders. If they are the same you're good to go. Personally, I believe they are going to be different. Look up both parts on a parts website like Autozone or Advanced Auto.
You might have to also change the brake lines at the master cylinder. With power brakes the master cylinder sticks out further than manual.
| All times are GMT -8. The time now is 03:48 PM. |
