3 link rear susp. on dirt track car
need some help on getting my dirt track street stock w/ 3 link rear end tighter getting off the corner car is real good everywhere else except loose off corner when getting back on thottle any advise i can try?
if the bisket on ur pull bar is wore out you will lose a lot a bit comin out the coner and losing you up. had the same problem with our super stock. those biskets our no good usally change them bout ever 2 or 3 races
| All times are GMT -8. The time now is 07:22 AM. |
