front end shake
i have a 87 camaro the car drives good but after a wheels up launch car goes into bad front end shake. anybody experience this problem with there car if so what did you do to fix the problem thanks.
have anyone install steering dampers on there car and did they help.
Shake
Have you checked front wheel bearings, tie rod ends, center link and ball joints? What about the shocks? Have you tried different wheels and tires? Is the alignment within specs? Has the car always done this or is it a recent problem? Has the frame been damaged? Is the front end tied to the rest of the car with the cage?
Just some things to start with. |
no it recent problem i have check all the front end parts looks good and thigh but it just started doing this, it's got me puzzle man.
upper & lower control arm bushings?
only have lower and they'er thigh.
oops didn't catch year of car :oops: :oops:
| All times are GMT -8. The time now is 06:25 AM. |
