-   -   Chinese look a like Little-M block (https://www.racingjunk.com/forums/showthread.php?t=25339)
hink 08-15-2009 12:38 PM
We have one in shop right now and have looked it over and checked it for brinnel test and it seems to be a very soft block as it tested in the low 140's
To give you an idea a 010 block is around 180ish and SHP block tested mid 190's and the Little-M and Big-M are mid 230's because of the nickel content.
It lools like the block is finished honed and I have not probed it out for locations for deck heights, cylinder bore loctaions, lifter bore locations ETC.
Looks like once the cylinders were honed they decked the blocka nd left a burr at the top of the cylinder as there is a zero chamfer on the tops of the cylinders.
The lifter bores have a huge ridge at the top and on the bottom of the bores I would assume from machining the soft cast iron.
With that soft of bore it would wear the cylinders out in a short time as well as the lifter bores.
The rear main cap is not even flat where the pump sets on and they have welded what it looks like a insert where the threads are.
I will post pics later on and what we find for demensions in another thead.
For right now it does not look like a very high end peice and is surely a copy cat of the Dart Little-M block
I beleive PBM is selling them with their name on them!!
Tod74 08-15-2009 01:18 PM
Are these blocks better or worse than a factory 400 4 bolt main?
TheYellaBrick 08-15-2009 01:58 PM
BUY AMERICAN !!!
mopar1962 08-15-2009 02:14 PM
x2 140? thats weaker than a standard block.Time to pay a visit....
Tod74 08-15-2009 05:21 PM
Originally Posted by DrivingMissDD
BUY AMERICAN !!!
I agree but you probably have more China crap than you care to believe. MADE IN AMERICA doesn't always mean it was MADE IN AMERICA.
FACT!
MEMRACING62 08-15-2009 05:25 PM
SAD BUT TRUE :cry: :cry: :evil: :evil:
FullTimeRacing 08-15-2009 06:24 PM
Only a %(I belive 60) of total cost OF THE PRODUCT including advertiseing to be called "MADE in the USA" :roll: :roll:
Tod74 08-15-2009 08:22 PM
I worked for a company that had some stuff made in CHINA then unboxed it, washed it in a hot tank, stamped the part number on it with a pin stamp and "USA" and repacked it.
OneBadGMC 08-15-2009 11:40 PM
You know that's illegal right? The owners of the business can be fined and jailed by the US government for doing that.
TheRabbit 08-16-2009 05:54 AM
By the same governmant that's lying to us by telling me my TAXES WANT GO UP to pay for all these wounderfull stimulus ideas?! Sad, but you are right!
