Supercharger REPAIR?
Do Any of you Guys know of a Repair Service Here in Michigan,that can handle servicing a Weiand (GAS) Supercharger?
It will NEED someone that can do MORE than a strip Job?It has some Issues in the Gear and Rotor Department? Seems that it was apart before and Patched up?It had a Weird NOISE when Running(Gear Grinding)? It DOES NOT Spin Smooth? I have a # of a Fellow in the Indy Area that use to Work for,Prudome?But,i have yet to Reach Him? Let me know if you know of Someone? THANKS Greg 8) [email protected] |
Some one probably took it apart and did not shim it properly, so the rotors clashed a lil, then galled the aluminum abit making it hard to turn and sound like that. I dont know anyone in your area... sorry
Nobody that I know of in Michigan...
You might try http://www.dyersblowers.com/ They're up in Chicago. Could also try Oddy's in New York. http://www.oddysracingengines.com/oddy_contact_us.html Otherwise, probably the best place to send it would be RBS Superchrgers in Cali. http://rbssuperchargers.com/ If it's run improperly, assuming the rotors didn't touch the case, the rotors are more than likely junk. Have any photos? |
Haha, send me you junk parts!
Thanks for the responces!
I Know all about RBS.Dyers,ODDy and so on?Its a STREET Deal unstripped.I found a fellow in Kankakee,Il. I'll run it down there and see what can be done with it? NO PICTURES? The Previous Owner Deffinately should have Kept his Day Job? He worked at the Corner Grosery Store,in the MEAT DEPARTMENT.......! Later G 8) |
I'm a few days late.. but I always send my stuff to Darren, DMPE I think he does the best work out of any supercharger shop.. And he IS in Michigan as well, to boot!
Blowers
Just Finished bolting it on this Afternoon,and its PACKING AIR!
THANKS for the Help! Later G 8) |
Well what was ur diagnosis?
Blowers
The Gears on the Frt.Rotors had been,Beat on as He said and Realy BOGGERED up the Splines on the Rotors.The Gears were Actually Junk,along with being out of Time,New Bearings,ETC...! Also had a bunch of Stripped Holes in the Case that were Repaired.So,its all GOOD Now! Later G 8) |
repair
I know you already found someone, but for future reference, Don Gerardot outside of Ft Wayne Indiana does blower repair. Might be a little closer for some guys. http://www.gerardot.com/
| All times are GMT -8. The time now is 08:31 AM. |
