-   -   New Dart SHP Block (https://www.racingjunk.com/forums/showthread.php?t=25428)
bjuice 08-23-2009 04:17 PM
New Dart SHP Block
Ok Guys give your thoughts on the New Dart SHP Block...
Give your Good,Bad,Ugly of this New Block ( Small Block)
How much do you think it can handle etc...
hink 08-23-2009 05:13 PM
Re: New Dart SHP Block
We built a Procharger engine a couple of months ago that made just over 700 horse and no issues and Dick Maskins told me 2 months ago they had one higher then that and no issues I don't remember the exact number but it was higher then what I had.
Here are some links to lool over
http://speedtalk.com/forum/viewtopic.php?t=10758
http://speedtalk.com/forum/viewtopic.php?t=12112
bjuice 08-23-2009 05:36 PM
Hink do ya think it could handle 1,000 to 1,100 ?..i know this is probably stretching it.
I am also in the early process of building Procharger engine...going for the 1,000 to 1,200 hp range with the F-series intercooled Blow thru ( air to Air)
Got my rotating assembly...now shopping for a aftermarket Block.
hink 08-23-2009 07:02 PM
That would be pushing the envelope I would at least go to the Dart Sportsman blockas there are some tubo giys making 1200 or so with the Little-M Sportsman.
I have one with a 4.1255 bore, 350 mains , 9.000 deck, .904 lifter bores and will sell the for 2395.00 and ship free in the U.S. if that helps let me know.
Carl
