finished my buddies sbc!
ok so weve been workin on this 350 sbc .060 over for about 5 months now and we're finally done
its got a scat all forged rotating assembly, forged flat tops, and afr alluminum heads 210 cc runner and 205int and 160exh valves, harland sharp 1.5 rockers and a lunati 525int and 540exh cam, air gap manifold and 750 carb hes wantin a few guesses on power, i said close to 525 give or take what do yall think? |
5 months? its hard enough to keep a motor clean for 2 hours while assembling....lol
Good job, i hope it works out well for you 2 |
Re: finished my buddies sbc!
what do yall think? That things good for at least 600...maybe 625. |
CHASIN WOMEN AND DRINKIN HOT TEXAS BEER AGAIN :roll:
:roll:
what do yall think? That things good for at least 600...maybe 625. Dammit! :shock: |
With the low compression and the limiting intake> I'd say maybe 450HP-500 tops.
u need to tell more info on cam(solid or hydraulic then roller or flattappet)
also what is compression ratio? off top of my head ill guess 450 would be doing pretty well if 10:1 compression hydraulic flat tappet....tell us more!!! by the way the intake is fine unless u regularly take er up to 7000 rpms or higher |
hydrolic flat tappet, with a 10.5 to 1
I WOULD AGREE WITH RUSS67CHEVELLE 450-475
| All times are GMT -8. The time now is 07:36 AM. |
