-   -   squirters (https://www.racingjunk.com/forums/showthread.php?t=25460)
john910 08-26-2009 03:02 PM
squirters
the threads in carb that hold squirters in is stripped. is the any way to fix? not the screw. the part in carb. any help thanks, john
john910 08-26-2009 03:03 PM
squirters
sorry it is a holley 750 double pump
zipper06 08-26-2009 05:48 PM
They can be hilicoiled, but i don't know what thread (dia)and pitch(threads per inch) they are. you will also have to use a good sealant, probably a high-temp RTV, but they can be fixed to save the carb body.
jmarksdragster 08-27-2009 11:34 AM
It is an odd size, a 12-24. If you are in a hurry you can get the heli-coil kit at www.blp.com
You can find them on ebay as well, just takes time. Might also find one at NAPA. And NO RTV. The gasket at the top and bottom of the squirter seal it, RTV will mess things up.
oldandtired 08-28-2009 04:56 PM
Remember that this is a banjo type screw. The fuel has to be able to ride up the side of the screw to get out the squirter.
Dave
jmarksdragster 08-28-2009 07:25 PM
Dave
Get some drilled screws, no longer an issue.
