WHICH TRANS WILL WORK BEST
I have a 1987 camaro with a 383 stroker with 520 cam afr heads 202 and drive it to work most of the time 20 miles round trip looking for overdive trans but not sure which will be best and will hold up any ideas
700R4 built with the right parts. 8)
ive read somewhere u can build a 200 4r to handle more power than a 700 r4.i could be wrong,but actually im doin a build similar and i pulled out the metric trans for the 400 i got lying around
I've got a 200 4R in my 1979 Elky, it's been in there since 2001, it's built with all the Grand National parts, double ring servo,etc. I don't have much HP just a 350 with trickflow heads, headers, and a 750 carb, 373 gears. It been down the 1/8 at .846, and driving it to and from the track, or anywhere else i want to go. I'm not saying it's stronger than a 700 R4, but it's lighter for sure and it works for me. I do have the manuel lockup switch for the converter, although it goes into overdrive without activating the switch.
Zip. |
Zip. those little Trick Flow heads are under estimated..its a decent head. |
Zip. those little Trick Flow heads are under estimated..its a decent head. Zip. http://img.photobucket.com/albums/v5...l_Camino-1.jpg http://img.photobucket.com/albums/v5...2/000_0003.jpg |
thanks zip, a couple more for my wall of fame.
Clean Elky Zip. (The Malibu is pretty clean too)
I remember that funky Christmas tree, it was red light city for me had to wait till the green came on pratically.
Zip. |
| All times are GMT -8. The time now is 12:59 AM. |
