OMG I cant believe this head failure????what kind is this???
http://www.yellowbullet.com/forum/sh...d.php?t=167969
I saw this and couldn't believe it! Wow,a head failure,what kind were these?My first thought was a different brand,but oh my god,another "expensive"'' brand name failed,I dont believe it! |
Looks like a casting issue and alot of spring pressure
i do not know what is so hard to believe...this is High HP racing... CHIT breaks...After all its Just metal anyway you spread it.....thats just part of it......before i could be dis-mayed i would have to know just how many failures these heads have had in this particular area.....otherwise its nothing unusal to see stuff break and come apart.....
My opinion |
Bjuice,this is my point exactly,but it takes a seasoned veteran like yourself to see and realize this,thank you for your experienced observation to this.
Bill H
View Public Profile Send a private message to Bill H Find More Posts by Bill H 09-08-2009, 11:36 PM #43 JUNKMAN1 Senior Member Smoked another BBC Join Date: Oct 2008 Posts: 1,823 Re: More CFE JUNK ! -------------------------------------------------------------------------------- Quote: Originally Posted by josh peel Porce casting is the answer to this problem. CFE/BMF heads are a Canfield casting. If you look at the material around the front head stud,there is only .80" of material. I had one do the same thing. More like a ProComp casting. ------------------------------------------------------------------------ just to take a quote out of the thread you(gunho) posted. people associate junk to procomp,this is post #43 |
ok so CFE/BMF and procomp are the same? so by pointing this out you are saying the CFE and BMF and Canfiels are the same as procomp? p.s. you should save up and paint that thing in your avatar........ :D :lol:
Also why do you concern yourself with other peoples cars when you dont even have one yourself? |
don't need to save,just don't care
go complain on yellow bullet to the guy that posted it dummass.
Pow, bang, boom gotta love a litttl erock throwing once in a while.
CFE/BMF have had quite a few problems over the last couple of years. There are stories of brand new heads failing on start up due to thin casting areas, Bottom line, no guarantee with racing parts, chit is going to break sometime or another, If it has not happened to you, consider yourself lucky. |
| All times are GMT -8. The time now is 02:43 PM. |
