-   -   flat tappet vs roller (https://www.racingjunk.com/forums/showthread.php?t=25653)
et7333 09-10-2009 02:16 PM
What do you guys think if I switch my current combo:
383,13-1,.558 int,.550 ex,260,[email protected] comp flat tappet,stock 215 Dart Iron Eagle Platinums,Manley 6 inch rods,Super Victor port matched,750 APD Alky carb, in my 3100 lb 68 camaro,to a COMP ROLLER#12-906-9,.276,[email protected],.630,.630@107?How much H.P. do you think this roller will gain,if any?
JimmySmith 09-10-2009 04:01 PM
camshaft
May I ask what gear and tire, do you run 1/8 or 1/4 also how much rpm do you want to turn your motor. Later J.Smith 4621 racing
et7333 09-10-2009 04:48 PM
I use a 4.56,9x30 with 94 inch rollout phoenix slick and run 7000 in the 1/4
cepx111 09-10-2009 08:27 PM
I'd say an easy 50Hp over what you got now, maybe more.
Everything you mentioned in your combo is screaming for a solid roller cam.
You won't be disappointed.
JMO>Cp
zipper06 09-10-2009 09:14 PM
I'm not in disagreement with Charles on this, but i did a similar swap about 9 yrs. ago in a 406", from a .595 lift flat tappet cam to a .625 roller 106 lobe ctrs. spent close to $1,000.00 and only gained 1/10, but i have to admit i've never in my life time of racing seen a better flat tappet cam than the .595 bullit cam which i still own. My friend Jimmy Smith can verify this because he knows when i did it. There's no question in my mind that the roller should run better, it just did not do that in my combination @ 3250 lbs.
JimmySmith 09-11-2009 05:02 AM
camshaft
My opinion probly will make more HP but not in the usable range. two things i say 60' will be slower , This cam should be in a 2500lb car turning 7500-7800 put a 255-263 or 260-265 @50 and you will like it a lot more. Facts with my car 3200 lbs 5.38 gear and 97"rollout tire Later J.Smith 4621 racing
et7333 09-11-2009 07:07 AM
I think the roller I mentioned won't work..I'm considering Comp's 12-920-9,which is 260,[email protected],.660,630 with a 106....My current flat tappet combo runs 10.32@130 @2000 ft in a 3125 68 camaro.I agree with you zip about rollers,I don't want to spend $1000 for a tenth.I was hoping for a .15 to.2 gain,if not I won't change to roller.
JEFF69Z28 09-11-2009 08:08 AM
USE 1.6 ROCKERS AND BRING THAT LIFT UP IN THE 680'S.CALL COMP CAM'S AND TELL THEM YOUR CAR COMBO AND HAVE THEM GRIND A CAM FOR YOU.THATS WHAT I DID IT COST ALITTLE MORE BUT WELL WORTH IT.JUST MY 2 CENTS.
