-   -   AIR BAGS (https://www.racingjunk.com/forums/showthread.php?t=25658)
JEFF69Z28 09-11-2009 03:00 AM
AIR BAGS
86 MONTE CARLO SHOULD I INSTALL BOTH OR JUST ONE ON THE RIGHT SIDE OF THE REAR END
Tod74 09-11-2009 08:13 AM
My opinion is right side only is all you need. You need to preload that side since that wheel is trying to lift off the ground. I suppose two would let you adjust more but I always ran 1 in my Chevelle.
jmo
JEFF69Z28 09-11-2009 08:29 AM
Originally Posted by Tod74
My opinion is right side only is all you need. You need to preload that side since that wheel is trying to lift off the ground. I suppose two would let you adjust more but I always ran 1 in my Chevelle.HOW MUCH AIR?
jmo
HOW MUCH AIR SHOULD I START OUT WITH?
Tod74 09-11-2009 09:44 AM
7 -8 LBS IF I remember correctly. It's been a long time since I ran that car.
