oil in water
have water in one cyl. worst case what am i looking at thanks
Blown head gasket, cracked head, cracked block
Bent rod, cracked cylinder.....
you might want to change your Focus on looking for the cheapest thing..
leaking intake ?... :D |
No matter what, ya gotta yank the intake and the head anyway to get a looksee....
If the motor did not quit spinning due to the water try a can of K&W Block seal. Follow the directions on the can to the "t". I have seen miracles with this stuff. We all get in situations where we need it to last a little longer and this will do it.
I agree with Brian dont get to ahead of your self.
I had a similar occurence , water in the oil - I was dead set it was a blown head gasket(s) at minimum. I had all my tools out ready to yank both heads and the cherry picker handy, just in case. I slowed down after pulling the intake and did a close visual inspection on the gaskets. Whollah! found one gasket that had been leaking. What a relief. Luckily I didnt get to carried away as I didnt have either header off, nor the V/C's. Point is a: It's never a bad idea to be prepared for a worst case senario, but then agian, dont fix what aint broke either. JMO>Cp |
thanks for all the replys put in the shop tare it down inspect for the worse
| All times are GMT -8. The time now is 02:00 PM. |
