-   -   TH350 AND BBC (https://www.racingjunk.com/forums/showthread.php?t=25751)
jreiley 09-19-2009 06:22 AM
TH350 AND BBC
Will a th350 bolt up to a bbc?
fla1976 09-19-2009 06:35 AM
350
If it has the Chevrolet bolt pattern.
There were TH350s in Buick, Olds and Pontiac., but the bolt pattern is different.
If it was behind a small block Chevy it will fit the BBC.
jreiley 09-19-2009 11:28 AM
That's good to hear. It was on a sbc. Save's me some bucks, for awhile.
chevyfireball 09-19-2009 04:09 PM
I'd be looking for a TH400 in the meantime.
fla1976 09-19-2009 04:47 PM
TH350
X2 on the 400.
silver86 09-22-2009 02:29 PM
will the bop th350 trans also fit the chevy engine?
Drtmod5 09-22-2009 02:33 PM
Go back & read the 2nd post! :shock:
cepx111 09-23-2009 02:56 AM
Yes, several companys make a adapter plate that allows you to bolt up a BOP TH350 to a chevy motor.
http://www.compperformancegroupstore...ct_Code=230000
Cp
cepx111 09-23-2009 02:58 AM
Till that big iron shreds that weakling!!!
I'd go with a TH400 or a powerglide depending on application.
Cp
Scooterz 09-25-2009 11:53 AM
My Trans builder here in Oregon (he is a bracket racer) told me that a good built TH350 is only acceptable to about 450HP. He will not build one if the application is over that. TH400 is the way to go.
